First Posted by me here - http://www.ocforums.com/showthread.php?p=4919942#post4919942
Ok, first of all MANY MANY Thanks to our very own ViperJohn for bringing this to my attention - you rock :attn:
Right then, iv been reading around online and it seems im not alone in my dislike for the new nvidia 8800 series driver layout (which imo is clunky and akward), which to cap it off wont let you go back to classic mode - AND its stupid insistence that if you want to overclock or monitor your temperatures you have to install ntune...which in itself is another clunky app which installs extra services to run on your pc..... all in all, it feels a bit unneccesary just for temps and a few sliders....
So, the fix, courtesy of ViperJohn, myself and a bit of experimenting with my 8800gts
Firstly - to restore the nvidia drivers to the classic control panel simply:
Bingo! The classic panel is back with a vengance.
Now this got me thinking, if the classic panel now works again, maybe coolbits will too? So I download coolbits2...install and presto - Nvidia drivers now have FULL temperature monitoring AND the ability to overclock again...complete with coolbits sliders for core and memory
Iv been trying it out and the clocking and temp monitor both work perfectly - no ntune needed and drivers that are easy to navigate!
So there you go 8xxx series users - get the classic control panel back and use coolbits again!
ViperJohn said:Open NotePad then copy and paste the following into a text document and then save it with
a "NV Classic CP.reg" file extention. Use the quotes when you save or Notepad will add a
.txt extension onto the file which you do not want.
Windows Registry Editor Version 5.00
; NVIDIA Windows 2000/XP Display Coolbits file
; Copyright (c) NVIDIA Corporation. All rights reserved.
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global]
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\NvCplApi\Policies]
"SedonaDisable"=dword:00000001
"ContextUIPolicy"=dword:00000001
"TaskbarUIPolicy"=dword:00000001
"CplGroupUIPolicy"=dword:00000001
After saving right click the NV Classic CP.reg file you created to merge it into the registry and
bingo you have the good old Classic (and useable) CP back.
