Overhauling my PC
Thanh55
Hi Everyone!
My first mod on the ThemaltakeAmor with water cooling is my project.
Cut top pf case for 1st radiator.
And change the position of the PSU so the radiator sit on top of PSU.
Cut the bottom for the 2sd radiator.
Made the VRM block for my AB9 QuadGT because I can't find a wataer block for it.
Mod the front panel and I don't like 2 wings in front so get it off.
Start painting the case and everything.
Some stuffs come in through the door
Put everything together. I'm on my way back to my pc:)
Test leaking and it seem to be ok.
I left them run overnight so hope have some news tomorow.
That is one heck of a case mod. Excellent modding to top and bottom. Really nice improvised block too.
Only thing that does my head in, I`m not sure u can do anything about, and that`s the tubing >.<
Holy mother of tubes!!!!! But I have no room to talk, my wires are outa control! Looking good :yumyum:
ROFLMAO, it sure is a rats nest of tubing :p. Nice case modding though mate. Keep us posted
I'm not experience on the tube so it's look like the box of tube (shame on me).
I order the dust filter already for the top and bottom.
if you change your loop about a bit and use another color in the 2nd loop(to make 2 colors of water) i think you could make it look a bit better.
still very very nice though:yumyum: :cool:
Nice mod!
After looking at the entire loop I've seen where you can cut a good 5' of tubing out though, which would make it a helluva lot cleaner :)
Yep agreed. I'll see if I can post up some images of alternative loops for you mate when I get home.
So what should I do now? take out the water and re-run tube? The water run like this: from the res to pump to rad to cpu to gfx to rad to NB to VRM and back to res. But I hit the bottom rock to day, when I tried to start my pc the 1st I turn on something like "lightening" (hope you know what I mean) somewhere on my gfx and the screen go black (nothing) I think my gfx just died :( :(
find a tube that isnt neer anything vital, disconect it, have a bucket ready, and some paper towels, and voila :)
Get water out today, just order new gfx (got the xfx 8800gtx). Hmmmm cost me fortune with this mod, hoping my mobo fine otherwise more than 100 quid have to spend.
