ok my cpu was overclocked to 2.15ghz and all the time time i overclocked more my ram was giving errors. and im sure that the ram can't go higher because it's a cheap ram which i bought and which i have to stay with for quite along time
. anyway i decided that maybe i should try use a different memory:cpu ratio to overclock my cpu more whilst keeping the ram stable.
my current overclocking so far is:
Ratio 5:6 ( mem:cpu )
Mem: 186mhz ( 186*2 =372mhz effectivley ) @ 2.6v
CPU: 2.24ghz ( 236*9.5 ) @ 1.8v
mem timings are: 8-3-3-3
when i try increasing the cpu more it starts giving errors so i can't increase the fsb more so at least the ram would achieve a 200mhz clock ( 200*2=400 ). i also tried decreasing the multiplier but once i get beyond 240 fsb it starts giving me errors ( maybe it's the bios. gonna go and update it ). i need help to at least to make the ram run @ 400mhz ( 200*2 )
Before this overclock:
Ratio 1:1 ( mem:cpu )
mem: 215mhz ( 215*2=430mhz effectivley ) @ 2.6v
CPU: 2.15ghz ( 215*10 ) @ 1.6v
mem timings were: 8-3-3-3
i tried increasing mem voltage and loosening the timings before changing the cpu ratio so i could achieve i higher overclock but still no go. my ram is really keeping me behind ( too bad i have no money
altough cpu is running @ 1.8v temps went down instead of higher and i arleady had this kinda strang thing and maybe it's because my cpu is a downgraded cpu. temps are 28 idle ( before: 35 ) and load are 37 ( before: 42 )
any help appreciated. i wanna get the best out of my rig.
EDIT: does it have anything to do with maybe the sata ports aren't locked?
