bluethunder
im trying to get my i7 970 to 4ghz(200x20) on a msi big bang xpower motherboard it runs in prime95 for about 20 minutes then i keep getting the bsod with error code 7f, that is the only one i have seen, can someone please lend me some advice as to how to fix it
all the settings i have changed
my bclk is 200
multi 20
ram timing 9-9-9-24 @ 1.5v 1600mhz
qpi freq 4.8gt
cpu vdroop low vdroop
cpu voltage 1.312v
cpu pll 1.88v
qpi vdroop low vdroop
qpi volt 1.27v
ioh volt 1.25v
dram volt 1.5v
spread spectrum disabled
eist disabled
cstate disabled
c1e disabled
over speed disabled
HT on
execute bit support disabled
cpuid max val off
my bclk is 200
multi 20
qpi freq 4.8gt
cpu voltage 1.312v
cpu pll 1.88v
qpi volt 1.27v
ioh volt 1.25v
dram volt 1.5v
eist disabled
cstate disabled
c1e disabled
over speed disabled
HT on
cpuid max val off
