overclocking help
sarmad
hi
my problem is that i cant run 3dmark 06 tests on my pc with fsb 380 and
timing 4.4.4.12
my hardware:
c2d 6400
patriot 2x1gb pc 6400 timing 5.5.5.15
aw9d max (14 beta bios)
my voltage and other setting :
cpu voltage : 1.325 or 1.35 (make no difference)
memory voltage : 2.35
mch voltage :1.60 (higher or lower make no difference too)
cpu ferq:3.40 ghz and timing is 4.4.4.12
when i run 3dmark 06 sometimes it pass the first test but sometimes not and
display a "dont send" error message or blank screen until i press the
escape key and 3dmark closed automaticaly or if i run "super pi" it well
calculate the 32mb for the first time and if l run it again this message appear
"not exact round " or somthing like that. so whats your idea about the
voltages value ?
should i change any of them to higher or lower?
is mch voltage important? if yes what value i have to set?
thanks
name='sarmad' said:
c2d 6400
cpu voltage : 1.325 or 1.35 (make no difference) trust me, it does make a difference, 1.5v is the general max for 24/7 usage. Try small increases and re-run benchmarks etc until you find stability
memory voltage : 2.35 seems quite high, is your mem rated to this voltage? 2.2v is common
mch voltage :1.60 (higher or lower make no difference too) I had mine set to 2.0v on high overclocks... Try 1.65/1.7
cpu ferq:3.40 ghz and timing is 4.4.4.12 for this frequency i'd imagine you need 1.45v but this depends on if you got lucky with your cpu. With memory, loosen your timings to 5-5-5-15 while you get a stable cpu, then re-tighten them
voltages value ?
thanks
The above error messages are due to instability.
1. Set mem to 5-5-5-15.
2. Increase v core slowly, at each increment try benchmarks.
3. Don't exceed 1.5v on your cpu.
4. Add a little to vmch, it does add stability.
5. once cpu is stable work your mem timings down
Let us know how you get on
thank you Mr. Smith for your nice reply
i'll go for it when i come back home ,and another question is that
why i cant stable it on 4.4.4.12 timing with this ferq?
is it because of low voltage or my poor hardware ?
thanks again
thanks again
No problem mate.
You might be able to get 4-4-4-12, as a general rule you find your max stable cpu OC then work on your memory timings... High latency seems to bring stability to high OC's...
I beleive your problem to be low voltage, you have decent hardware...
hi
finally in 4-4-4-12 timing its stable with this setting:
vcore:1.35
dram:2.10
fsb:350
mch:1.50
(passed the "prime95" and "3dmark 06" test)
and if i dont change the timing and set it by SPD :
fsb:390
vcore:1.35
dram:2.25
mch:1.55
i am sure my pc can raise higher than what i found but i have to work on it .
and another thing is that why the 14 beta bios is more suitable than 15 beta
bios? and how i can find out what refresh cycle time value is correct for
4-4-4-12 timing?
thanks for your advice
