Overclocking 6870
DT-525
What is the most you guy have been able to get out of a 6870. Just thought i would ask. I'm not a big overclocker but though i would try. I have the XFX 6870 black so it's factory overclocked. Do u think i would be able to get any more out of the card.
This is the standard setting of the card.
And this is what i have been able to get out of it. Its not the stable. It will run the metro 2033 bench ok but when i try the crysis bench it messes up the screen and i have to reboot.
I'm using two Asus reference 6870's at 950Mhz/1105Mhz GPU/RAM and at stock voltage. As far as I remember, I had less luck overclocking the RAM. I stopped there since the duo is already overkill for the games I play. I didn't overvolt since I'm aiming at a quiet PC.
