Opteron 144
Ares210
Well seeing the huge price drop in processors I am thinking of picking up an Opty 144. I was wondering if anyone knew what kind of clocks i could get with it and how big, if any, of an improvement would it be from my current Venice 3500+ @ 2.53. (am running a Zalman CNPS LED)
I'd say roughly 2.6ghz would be a reasonable number to achieve with that processor and the right cooling. What kind of cooler do u have right now mate?
And the improvement would be a decent one, considering the single core to dual core jump. And you can fold 2x as fast for 43461! I think it's a win-win situation if u ask me, muahahaha.
Umm, tbh i wouldnt bother. The Opty and venices are pretty much equal clockers in my mind.
I'd invest your money in different areas if you want a better overclock, or save your money for a more major upgrade later on.
Wow I could have swore I was posting in a thread about an x2 4400 or something. Jesus my mind is playing tricks on me.
Well it does throw in a 1MB cache as compared to 512kb which is a pretty considerable jump. Also, knowing how crazy that opteron OC's, at least 2.6 I would guess up to 2.9, clock of 3.0 and higher are not unheard of on air.
All of the new ones are mad binned though, I wouldn't expect any amazing clocks from it, but now seeing what it is that we're looking at I would say that 2.8ghz would certainly be attainable with that chip.
and that extra 512kb makes the cpu SLOWER when running superpi for example.
not one certain benchmark, several benchmarks such as pcmark sisoftsandra and 3dmark01 for example and all results showed basicly the same.
the cache difference had no major impact whatsoever that can even remotly make it worth the extra cost for a normal homeuser.
pcmark04 differed less then 15points
superpi 32m was 34seconds faster with 512kb cache
512kb cache was also 500 points faster in 3dmark01
memory bandwidth, cpu arithmetic and cpu multimedia benchmark scored basicly the same in sisoft sandra.
googled some more and found a test showing only 50points difference in 3dmark06 so as i see it its just a waste of money to aim for 1mb cache just for the "name" of it as the benefit as a normal homeuser is more or less nothing as it is now :/
I've heard of much more performance gains in regular usage, but either way, he will still probably obtain a higher clock with the opteron, and best case scenario, he can sell his current venice for about $50.00 covering 2/3 of the costs.
I've had an Opteron 144 for awhile and I know you'll be able to get AT least 2.7 with moderate cooling. Get a nice air cooler or watercooler and you are looking at 2.8-2.9 (and quite a few have gotten 3.0+ on watercooling with a great chip, alot took the IHS off to have better contact though)! Mine has been running at 2.9ghz for quite awhile at 1.4125 volts which is almost stock. I can run 2.75ghz at STOCK volts...those chips were great at the time and i'm sure they've only gotten better so for a cheap price you can have a great OC'er. When I got mine they were around $180 and it was worth it even then. I'm sure they're alot cheaper these days. I remember seeing a dual core X2 for less then $150 a few months ago so if I were in the market for a new chip i'd definetely go dual core!
Ive had my Opty for a bit now..it was one of the first 06 chips that made into the market place and its been running great. Alot had said back then that the 06 chips werent going to OC as good as the 05 chips but that clearly wasnt the case. The stepping on my chip was CAB2E 0602DPGW. Everyone I've ever known that has a 144 has always OCed to at LEAST 2600 with average overclocking knowledge/skills. Anyway, since the dual cores are so cheap if you can afford the little extra i'd go for one of them. It'll be a better choice in the long run. Just my 2 cents of course! Good luck...I sure do love my Opty 144!
I had a 144 and a 3700+. Maybe the 3700+ was a fluke but it was a OCing dream to me. Even though I am OC challenged (I suck at it) I was able to get my 3700 to 2910mhz and ran it at 2750mhz 24/7 on my Biostar Tforce mATX mobo. I didnt have near as good luck with the 144 so I sold it and got a 148(what a dummy, I paid $250 a couple mos ago for the 148)
