Hi. I know there are a few threads out there but would just like some opinions on the subject on the importance of WHEA error 19 that is corrected by the CPU. I have watched Tom and some other overclock guides and I never hear them mention WHEA or check for them in the logs. Some have posted that WHEA should be considered just as unstable if you get failure in Prime, OCCT, IBT, Linx etc. I can complete endless hours of these tests on my 3770K at reasonable voltages but Prime typically will generate WHEA. I then have to go up 2 or 3 vcore steps in order to eliminate these. Should I even be concerned with these as I never see them under ordinary use? Thanks for your expertise.
