Ragnar_Mike
So my sister is attending art school and will need a pretty decent rig to work on her art. We're going for something compact so mATX is preferrable.
She loves either the LIAN LI PC-Q08R (which is micro itx) or PC-V354R so I'm going on the assumption that I can find them somewhere in the states. I know I can get the Q08R, but the V354 will be a bit of a challenge but worth it.
Anyway, her uses are as follows:
Photoshop and Illustrator
Rhino/Zbrush (3D Sculpting)
After Effects
So predominantly 2D work but with 3D modelling/rendering on the side. My rig is beefy and has said software so if she needs something rendered fast, mine will usually be available.
My current build thoughts
i5 2500k
CPU cooler (whatever I can fit in there, probably an h50/h70 or stock)
8gb DD3 1600mhz Ram
1tb 7200rpm HDD
Z68 chipset mATX board
GTX 460 of some sort
Corsair 650w modular
Windows 7 Home Premium
We're trying to keep it under $1200, but obviously there's a little wiggle room there. I'm down for saving money so anything is up for being tossed. I'm not deadset on overclocking it either a nice bulletproof sturdy PC is a plus for her and running a 2500 and stock cooler would save some cash. Just a thought.
Feel free to ask any questions and I'll try and supply decent answers. No promises though.
After Effects
i5 2500k
8gb DD3 1600mhz Ram
1tb 7200rpm HDD
