Ok so be rig is ok its just a little bit muppety. The RAM is the above and is rated as 1066MHz at 2.2V stated with timings of 5-5-5-15. At the stock voltage i can get the timings (after some fiddling
) but only 930MHz (not bad really). The problem is when i put the voltage up to the "required" voltage of 2.2V to get 1066MHz it just refuses to boot. I have had it going at this speed but due to further tinkering i had to reset and cannot get back
Are there any muppet things i'm doing out of habit more than sense? Should i try cranking the voltage rebooting then the speed? or maybe the other way round?
Hardware:
Windows XP Pro x64
Asus Striker Extreme 680i
Intel Core 2 Quad Q6600 3.0GHz (1333MHz - 333 x 9) G0 stepping
2Gb OCZ ReaperHPC PC2-8500 (930Mhz - 465MHz 5-5-5-15-2T)
2x 160Gb SATA2 Maxtor DiamondMax +10 (System Disk and Documents)
2x 320Gb SATA2 Maxtor DiamondMax +11 (Audio and Video)
2x Asus Extreme 8800GTX (600Mhz, 1000Mhz, 1406MHz) in SLi
Thermaltake 1200W PSU
Asus MW221u Monitor
Artic Cooling Freezer Pro 7
Coolermaster 4-in-3 Hard disk cooler
Drivers:
1503 BIOS
9.53 680i SLi Intel Edition
163.75 8800GTX driver
DirectX 9.0c
All Voltages: [Auto]
Results:
CSS VST @ 1680x1050 16x AA 16x AF - 318.11fps
3DMark06 @ defaults - 16069 - 6138 - 7513 - 4778
Hardware:
Windows XP Pro x64
Asus MW221u Monitor
Drivers:
1503 BIOS
DirectX 9.0c
Results:
