OCZ Booster With ANtec Neopower 480
SGT_VC
OCZ Booster With ANtec Neopower 480 watt PSU are these compatible, I bought a secondhand Booster and I cant get it to work , I have read something on the net about the 5V rail if this isnt stable enough the Booster wont work is this true and is there nayway to test My PSu some util of some sort.
any ideas
thought better add PC spec
P4 2.4c 800 HT
Asus Mobo p4p800-E Deluxe
ATI 800xt AGP
1Gig 2x512 Ocz PC4000
Antec Neopower Psu 480w
Asus supply on the driver disk some sort of monitoring software - probably called ASUS monitor??
Load that up, it should tell you what volts you are running in each line (3.3v, 5v and 12v)
If you need a new PSU I am selling a Thermaltake 680w which I have had running with OCZ booster no problems.
Cheers
Mav
