Ocool waterblock
ugiboy
Hi, I am totally new to this forum, in fact I have never been on any forums so please be patient. I have just received a waterblock & backplate for my GTX590 from OCOOL, the instructions are very brief so does anyone know where I can get any from please. I have watched Tom's video but it does not deal with a backplate. I have never done any watercooling whatsoever before, bought a rig that already has it, I am upgrading (at least I think it is an upgrade from a HD6970. Hope to spending a lot of time on here. Hi to everyone, and like i mentioned please be patient with me.
You can see why someone would make the mistake :P
I ran a google search of 'OCOOL' and all that really came up was this thread! I dismissed it as a mistake on my part, but I think you've cracked it :)
Are the bolts that come with the backplate longer than the ones for the waterblock? If so you probably just bolt through from the backplate into the waterblock. I.e. bolt -> backplate -> spacer -> pcb -> waterblock.
Sorry!!!!
Hi, Sorry for any confusion i may have caused. It is Alphacool I meant to put. It is a bit confusing because on my waterblock in copper coloured letters it says OCOOL. I have now installed my GTX590 with Alphacool waterblock & backplate, it was much easier than I thought. Just waiting for another block to be delivered to install my second GTX590. next on the list will be motherboard blocks & adding a second radiator. Thanks to everyone for being so friendly 7 patient with me.
