OC3D Review: XFX 9600 GT XXX Alpha Dog Edition 740M 512mb
Nice review Matt.. Detailed as ever.
Neither of the 9600s are for me, but its good to see XFX bringing out an Alpha Dog editions as like you said it needed a little boost from stock to bring it in to a decent bracket.
Great review m8. £114.. I mean we call it a "mid range" card, so arguably it`s a higher-mid-range for the 9 series, but the nVidia cards at present are all over the shop imo. - unless you forget about the 8 series completely.
Personally I like to compare the x6xx card with x6xx in the same series and the series below - only cos mid range is mid range - but it competes with the 8800GT in many respects, including it`s ability to clock better, and supposedly SLI better. `Would u SLI 88GT or 96GT ?`, many would say 96GT if that were the choice.
Then again also, XFX pushing the card very well imo.
the 8600GT was quite exceptional, performance and feature wise
this is...medeocre, in comparison to the 9800GTX
wheras the 8600GT was just a cut down version of the 8800GTX
I swear you don't actually read half the reviews we do ya know...
i do read them, but i also owned a 8600GT, great card it was too...
looking at the comparison of this to the 9800GTX it doesnt perform aswell as an 8600GT would when compared to an 8800GTS 320mb, IMO
unless you think i'm wrong ofcorse?
The 9600 GT performs a fair amount better than the 8600 GT would, even when taking into consideration the generation cards.
i dont doubt that, the point i was making, was the gap in performance between the 86xx and the 88xx is probably less than between the 96xx and the 98xx
ahh, okay, so they're closing the gap performance wise? ...hmmmm....that doesnt make good business sense
they should all increase, all levels of cards, but only by the same amount, in the same...incriments....otherwise one level will get too high/too low, and merge into another...
damn u guyz bang out reviews fast. nice review tho. wasn't likin the stock 9600 much but this looks better
