Great review, Jim, but as stated, the design looks rather poor. Although it performs, I'd probably check around for other alternatives before settling with this one. But then again, I tend to go for bigger HDD's, screens and such, as it is a notebook.
I have a feeling the 7200rpm drives generally use more power - I judge that merely by having replaced some 5400rpms with them and noticing a great deal more heat. They work well enough tho.
Have to be honest, the design looks pretty cheap to me and the specs, although looking pretty good with the benchies don`t push me towards wanting to part with £850 for one.
Flimsy feeling case - for a gamer - it should be shrouded in rubber and polystrene black-taped to it (probably wouldn`t help with the heat tho lol)
Don`t like these turbo-boost ideas either. I can remember turbo buttons on old pcs.
Bet it works a treat tho, as per the great review. (I`d buy the Acer with the lesser spec tbh, or look for a newer spec`d Acer)
