OC3D Review: Coolermaster iGreen 430w PSU
JN
So you're looking for an affordable, reliable, stable power supply for that budget PC build?
Look no further than here
Raven said:
mtbf of 400.000 hours sounds alittle like a fantasy, its almost 46 years nonstop.
but looked good :)
Yeah, i'm not quite sure how they actually test that it's going to last that long...but needless to say the unit is going to be quite reliable :)
XMS, i wonder more how long the fan will last.
the longest i have seen sofar was 100.000hours and the fan in question had ceramique bearings.
similar is used in high quality eheim waterpumps and works GREAT in water which lessens the friction.
guessing oil is used for fans.
I believe they also do 500/600w versions. I wouldnt mind giving one of the higher wattage ones ago, to see if this efficiency & stability runs thru the whole range.
Yep, there are 500W and 600W versions. 500W retails for about $105 and the 600W for about $135 right now. Both boastin pretty high efficiency which is pretty cool... Strange that the 430W isn't listed on CM's US site...
nice reveiw jim,looks a nice psu for a budget/low power build:)
nice to see more top manuf names coming into oc3d reveiws:cool:
cheers.
