nVidias latest card a little out of your league? Perhaps their cutdown one will satisfy your needs...
Continue Reading
Continue Reading
name='Ghosthud1' said:silly pricing......lower it by £50 and it could sell alot.
name='VonBlade' said:Feel free to point out which card is more expensive than a GTX480 Rasta, cos the most expensive ATI offering, the 2GB 5870 Eyefinity 6, is still cheaper.
name='VonBlade' said:If you're going to pick and choose your cards I could just as easily counter with
http://www.scan.co.uk/Products/1GB-...GDDR5-GPU-850MHz-DisplayPort-2x-DL-DVI-I-HDMI
£322
http://www.scan.co.uk/Products/1536...0MHz-Shader-1401MHz-480-Cores-2x-DVI-miniHDMI
£393
Cheapest of both models that you could go and buy right this second.
So there is PLENTY in it.
name='Rastalovich' said:Don't be silly, when you're wrong, you're wrong. That's the 1G version. And the point in fact, as you well know, is the statement was that the 480 is the most expensive single gpu - which it obviously isn't.
The foolish thing to do is to back yourself into a corner arguing the point.
