wow still awake and working? apriciate it very much thanks!
Very cool thank you but for some reason the red logo is only 1900x1900 or is the 4K one only the first logo ?
Here are the OC3D logos retraced in high resolution ( 4712x4712 ), Perfect to use as a wallpaper. Feel free to request OC3D logo in a different colour
All logos should be 4K, i think google has been resizing, i will check
Would be neat if you made one in which the 3D part actually has the right color.
Thanks for the effort mate.
My bad I was right clicking and saving as instead of downloading
Love it, Straight to the point and blunt with zero emotion, You make our country proud ^_^
The 3D part does have the right colour does it not ?
The one on in the header looks different.
I could probably do this myself, but he said he'd listen to color requests, so i am going to be lazy.
Well don't forget the one in the header is the old one, The site is going to get a colour overhaul if I remember correctly as the red OC3D logo will be the new logo.
I like the oldschool colors.
Is the overhaul only going to change the colors or is the entire forum structure going to change? I really don't want this to turn into oc3d-reddit, i've seen that happening to a couple of forums and they all took a turn for the worse.
It's different.
why not just upload the vector file so everyone can pick whatever colours they want?
also easy to import into cinema4d etc. like that
