OC3D Aim_ag_texture2 DM server. Sv
As i said in the other thread:
get.php
These two commands will not stop actual cheaters anyway. Just people who decide to ruin the games looks via bright red and bright blue models and such.
And as I said, you need to update your SRCDS.
http://developer.valvesoftware.com/wiki/Sv_pure
Why else would my own and many other servers be using a unknown command, that works?
They will stop cheaters, they won't stop hackers. Which in turn is good enough because hackers will get VAC banned anyway.
I could right now google for glass aim_ag_texture2/or just replace the orange dev texture with a transparent texture. I could use neon models spiked gun models etc.
And there are many people that do so. I myself don't want to play with these people that's why I have kindly asked.
You make a good point. I must admit i thought i saw the sv_pure added only recently.
The servers had deliberately not been updated though, due too the fact the update plain broke the DM scripts (after the round time is up it declares CT the winner and restarts, spawning people at the normal points). Last time I checked the pulg-in hadn't been updated for it either.
Ill have a word with XMS and see what can be done.
Thanks very much Ham, I appreciate it :).
It's been out for about a month now.
Pretty sure the latest runs fine with sv_pure 2 + sv_consistency 1 have you changed consistency to 1 yet? That should work fine for now.
http://www.bailopan.net/cssdm/
Latest and greatest, should work fine on pure 1/2. 2's better IMO it means the server isn't no slower than normal. Not sure about 1 I think it involves a little checking + caching.
12-11-2006 it's pretty old, I hope it works...
You could try this:
http://forums.alliedmods.net/showthread.php?t=57227
To remove bombs/hostages:
http://forums.alliedmods.net/showthread.php?t=39440
Any news?
Thank you. I haven't been able to play CS:S during yesterday so I wouldn't know if it has changed yet.
Thank you.
