WYP
News Guru
So, does anyone have a spare £2400 to buy this?
Read more about Nvidia's Titan RTX GPU becoming available for purchase.
You'd have to be seriously touched in the head to buy this.
You buying 2 then
Jokes aside I do agree with you, if you bought this strictly for gaming then you would need to go see a doctor, because you are just nuts.
The 2080Ti is already stupidly priced, yes nVidia need to try and recover some of the money spent on development but seriously there pricing is just getting almost as bad if not worse than Apple and that is saying something.
My 1080Ti will last me for a few years yet I think, the only 2 games that I intend to buy are Anthem which runs fine on my system ^_^ and The Division 2 which I need to upgrade my CPU for at some point![]()
I think 90% of these will end up getting sent to developers for testing, I think that's where most of their recent Titan's have been targeted at.
NVidia hand out free cards quite a lot(As do AMD), not just to game developers but many OS/software developers too, as well as research facilities.
Anyone notice the boost clock for the RTX Titan is quite a bit higher than the 2080 Ti.
What this means for actual performance who knows.
It's an ~8% jump over founders cards in boost clocks but roughly matching many of the "OC'd" top tier card boost clocks, probably doesn't mean anything if tested on the same cooler since heat output will still be the limiting factor at full load.
This forum officially lacks a dedicated like button.You'd have to be seriously touched in the head to buy this.
The question is why it higher than the FE even though it uses the same cooler and a fully enabled chip.
Are the cards using binned silicon?
TU102's core count was already at the point where it had to reduce is clock speeds against TU104 (2080 has a higher boost clock than the Titan) to have all the cores of the 2080Ti enabled in most cases. The slightly better minimum bin regarding maximum clocks at the target TDP is likely a requirement/implication/side effect of any TU102 chip that also aims to have every core utilised at full load at near base clocks for the target TDP. The 2080Ti was the closest thing you can get to a value bin on a 775mm^2 chip on a mature node, while the Titan is in line with what you'd expect for a full-fat chip.
I think this is the first time I have seen the full fat chip (Titan) boost higher than the XX80 Ti card.
