WYP
News Guru
It is now rumored that Nvidia will be using GDDR5X memory with some of their upcoming Pascal GPUs, offering double the speeds of GDDR5 memory.
Read more on GDDR5X memory.
Did I miss something? I've read that micron created it, but found no link to Nvidia whatsoever?
The rumor is that Nvidia will be using it, apart from that no information is really available, so i explained exactly what the memory was.
GDDR5X is significantly less complex to move to than HBM as it is so similar to GDDR5, making it a great option for them to use until HBM can be manufactured in required quantities and all manufacturing issues for placing it on GPUs are resolved.
So much for the pics with the die showing HBM.
I guess they couldn't get the license for it. Ah well, not going to lose any sleep over it.
When you say HBM, are you referring to the current 'AMD' HBM or HBM 2.0?It is likely that next generation GPUs will use HBM or GDDR5/x, with high end GPUs using the HBM and lower end GPUs using more traditional GDDR5.
It looks like HBM is in short supply, and why use the HBM on lower end stuff if it can be done cheaper with GDDR5 until production ramps up and matures.
And the rumour is accepted at face value and regarded as fact. And probably all because of some random guy spoke his mind in an obscure forum post somewhere. Oh dear...![]()
Could it be true? Sure, just as much as it might not be true. I'll wait for confirmation on whatever will be on what card![]()
Ps: I didn't mean you WYP.
This would be fabulous. Something tells me, though, that if AMD can get enough HBM2 chips, so could nVidia, and if they're not, maybe only AMD's flagship 'Fury X' and nVidia 'Titan' will have HBM2, with limited supply, and with lower tier GPU's still only coming with GDDR5 or HBM1. Is HBM1 limited to 4GB or was 8GB possible if supply could keep up?If it's enough of a rumor to get an article from more than one website then it it has a chance of being true. It's kinda like everyone saying Pascal will have 16GB HBM2 as a standard when that is obviously more of a fanboy wet dream. It would only appear on a Titan imo for the epeen
This rumor also contradicts the fact everyone is claiming Sk and Samsung will produce HBM2 for Nvidia.. now there's supply problems when we get another manufacturer producing it so they need to change to this? All rumors and that's why there's nothing being confirmed.
It would be interesting to see if Nvidia don't go down HBM2 while AMD will. It would mean more supply for AMD and since HBM2 is still faster and also will consume much less power it would give them quite an edge on memory and at high resolutions once again
I'm not as interested in buying AMD's flagship, to be honest. The 'Fury' (non-X) equivalent should be enough for 1440p gaming in 2016 and 2017. But if it still only comes with 4GB of HBM1, that might put me off a little. Hopefully they have their 290 (non-X) and Fury (non-X) versions of Arctic Islands with HBM2 and not just their highest end card.It's limited to 4gb. I don't think hbm supply will be a huge issue. With Samsung joining in to produce them there should be just enough. Samsung are pretty great at producing memory so I have faith in them coping with high demand. SK are also pretty good so we should be fine tbh
4GB is fine, yeah, but that doesn't stop the fact that I want more for my next card.4GB is fine for 4k even now. It won't be in a couple years but as of now it's fine. HBM2 can go upto 32GB so the next gen cards will probably all have them in the -mid high end and lower end versions might stick with HBM1 just because it'll more than likely be cheaper.
4GB is fine, yeah, but that doesn't stop the fact that I want more for my next card.In all seriousness, while 4GB won't throttle a GPU that should theoretically be as powerful as an overclocked 980ti, it will limit the performance slightly. In games like GTA V at 1440p, a 980ti can draw over 4GB of VRAM. The same for AC Unity. With my Fury I only draw 3.3GB of VRAM, but that's because the GPU is simply not powerful enough to run the settings that draw so much VRAM. If I were to gain a big performance with the next AMD 'second-to-top' flagship, I'll be able to push the settings higher. While 4GB would only limit performance by a little, I'd prefer that not to happen. Also, VR might eventually draw me in.
As others have mentioned there seems to be a shortage for HBM, so we can probably conclude that HBM 2.0 will be limited as well. This means only the professional and enthusiast (Titan etc) models of graphics cards are likely to be using HBM 2.0 in 2016.
Lets face it HBM in it's initial form didn't really impress anyway, certainly a lot of people expected more. So if they can almost double the bandwidth with GDDR5X, I say go for it! Makes no difference to me what it's named or how fancy it looks, as long as it kicks ass![]()
4GB HBM is fine right now since it has good color compression techniques... but there's no guarantee titles in 2016 won't push the VRAM envelope further though with Dx12 and Vulkan... if Vulkan even comes out in a different time frame... we are talking about Khronos Group hahaha.4GB is fine for 4k even now. It won't be in a couple years but as of now it's fine. HBM2 can go upto 32GB so the next gen cards will probably all have them in the -mid high end and lower end versions might stick with HBM1 just because it'll more than likely be cheaper.
Ahh, I'm just chatting. It's no worries. I'm not trying to preach or anything. I imagine next gen cards will have more than 4GB of VRAM.Next gen cards will guaranteed to have more than 4GB of vram as I already said. You kinda repeated yourself?:huh:
Also games will use as much vram as it can when there is enough available. That's why games running on a TX will consume a lot of vram because there is 12GB of it. If it's limited to 4GB it'll draw a lot less. Battlefield is pretty good example at doing this. However like I said already though, next gen GPUs will more than likely get large memory increases as resolutions rise and they both intend to be the better VR team, both are going to require more memory
