Nvidia NF4 drivers or DFI ?
ZaX
Lo Guys,
Just doing a fresh install on my main rig with 3 x 36 Raptors on the Si3114 controller (Raid 0) I was just wondering, which drivers for the NF4 chipset should I use Nvidia's or DFI's?
Thanks.
get the nvidia chipset drivers extract them and the raid drivers are in a folder
edit i see ya not using the nvidia raid
get them off the cd
definatly use the nvidia NF4 drivers. the lataest ones are the best. they can be found on nvidias website.
To be perfectly honest it makes booger all difference which RAID controller you use unless your trying to run SATA-II stuff. Only the nForce RAID supports SATA-II and not the Sil3114 controller.
Boardy
