Nvidia iCafe 340.72 WHQL Driver
Dicehunter
Resident Newb
This is the latest pre US and EU release, China are usually the first ones to get the newest driver branch as they have a huge cyber cafe industry hence the need for more stable drivers that offer better performance at faster release intervals.
I've tested it and it includes the previous release fixes i.e valley flickering etc... and all round performance is solid, As of right now there are no release notes but from testing and testing by others there is a 5% performance increase in the newly released Metro Redux games.
This release also includes the newest Physx driver 9.14.0702
Installation instructions
Once you have downloaded the driver you want to use an extraction program such as WinRAR to extract these to a folder for easy installation.
You can install the driver the standard way but I highly recommend this way for ease of use as you will need some of the files inside the driver package later on during the install process.
I have made a little video showing this simple procedure including installation of this driver without any hiccups on Windows 7 -
*Set the quality to 1080P*
As you see in the video please do not install the included HD Audio, 3DVision or GeForce Experience on the initial installation, The included GeForce Experience driver is for Chinese territories only and will not work on US or EU machines, I have included a download link for the latest EU/US version below.
The
3DVision driver should also be installed afterwards if you need it from within the extracted folder after you have installed the main driver, For some unknown reason installing it along with the main driver causes issues and an installation failure.
Download the latest GeForce Experience from Here
Installation Note For Windows 8/8.1 Users
If you are installing this on Windows 8/8.1 please remember to disable driver signing, As this is from another territory Windows will not recognize the driver signature otherwise.
Follow the steps in this video below to disable driver signing on windows 8/8.1 before installing the driver -
If you are curious as to what exactly driver signing is, Microsoft have a short and detailed explanation of it Here
Driver Branch Information
340.52 is r340_00-144
340.72 is r340_00-202 i.e newer branch.
Download Links
Only the 64 Bit driver is available right now.
Windows 7/8/8.1 64 Bit - Click Me
for me the download completes, but setup fails on extraction saying
Error during Execution ".\\setup.exe".
The system can not find the specified file
Will pull out the setup.exe out of a previous version to get the thing to co-operate if I can.
**Edit**
Strangely, it installs when run from the extraction directory.
It looses 3D Vision driver, and Geforce Experience when installing, but it will manually install.
**Edit**
That's why I said the best way to install is to extract them ;)
Update:
If anyone is wondering about a change log from the testing done and testing by others there seems to be a 5% performance increase over the latest WHQL's in the Metro Redux games.
These posts are awesome but this feels rushed, I know what you are trying to say and its actually not that clear even for me. Try and remember you are writing for other people and not yourself dude - an extra couple of minutes worth of text could have made this so much better.
Ok cleaned it up and added clearer instructions, Any more simple and it will basically be teaching people their ABC's lol ^_^
