Mysterae
Haven't seen this posted anywhere here - On Guru3D (credit where credit is due) they have discovered a way to enable Dynamic Super Resolution (DSR) on older Nvidia GPUs, not just the 900 series.
"Dynamic Super Resolution (DSR) produces smoother images by rendering a game at a higher resolution then downscaling it to the native resolution of the display using advanced filtering. DSR can be applied to any game and can be used with other antialiasing settings to improve image quality."
I noticed the DSR option wasn't present in the Global Settings menu of the Nvidia Control Panel with the 344.11 drivers for my 708ti's.
The workaround (until Nvidia enable it properly), is to install the 344.24 drivers which are meant for laptop GPUs. However it won't install right away on desktop PCs, you have to add an altered *.inf file to the extracted driver folder then run the setup.
Now I have both DSR options, DSR - Factors and DSR - Smoothness
