NovaBench
Rastalovich
Just for fun. It's a free benchmarking thing, small, unobtrusive, download here : http://novabench.com/, for both Mac and PC (although they run different graphic tests).
Gaming rig (that it looks like I'm keeping cos matey is ploughing more cash into something newer)
(CPU actually @ 4.5g, GPU @ 785)
Hackintosh Lion
(think these stats are correct, hmm ssd doesn't seem to be working very quickly)
Let's see what we got !
I was using this when I decided to get a new Machine, but upgrade this one with only the parts that could go in the new rig.
My first run I think I scored 336
After a few upgrades I got up to 3rd place in the list of machines running my CPU at 600 somthing
but after a little bit It wouldn't run the GPU test anymore, just froze up there, and I never was able to find out why....
CPU actually at 4.375GHz and the GPU was at 800MHz core. I don't know if SLI worked on the graphics test but I'm guessing it did not.
That sounds like your NET framework has a problem. How to fix that, or if you really want to to run this bit of fun-app, I dunno.
If you go back to the NovaBench download page, on the left-Windows download side, there is a link for framework 2.0 - you could download it and install to see if it fixes something. Then probably goto microsoft updates to update it.
i keep crashing too, everything is upto date and system is only running 4.3ghz and tame oc on gpu so very stable :/
updating thru widows update is what I think started it, I think the APP needs to be fixed to work with the latest framwork updates.
I tried updating evething , uninstalling it, nothing works.
