noctua NH-D15 orientation compatibility
katiekitsune
i'm using an ASUS ROG maximus VII HERO motherboard and will be using a noctua NH-D15 to cool the CPU. if i mount the cooler so it exhausts towards the top of the case (with both fans installed) will i be able to mount a graphics card in the top red pci-e 16x slot or will i have to use a lower slot?
It will fit if you place the second fan in the top as exhaust, on either the cooler block or attached to the case.
