no overclock on dfi nf4 sli-d expert
omegaman
HI,
just built my system, i cannot get any overclock ,soon as i alter the bios fsb the system will not boot....any ideas!!!!!
amd x2 4800
mach II regasses to 507
ocz el ddr pc-4000 gold vx
xfx 7800 gtx 216 in sli
2 x raptors
on my dfi nf4 sli-dr i could get 12 x 250
using orange slots,using 704-2bt bios,turned of throttling, now getting 240 x 12 ....
any more suggestions will be helpful
thanks
It would be helpful if you could list down all your bios settings that way we can see what timings you are runing and volts you are useing!
And what power supply.Isn't that bios for the non expert board?
as scorchio says set ram to auto all the way down the settings and add a divider in make sure you can get the CPU to overclock (without worrying about the ram).
The problem most people have is that this board does NOT overclock the same as the old non expert unit and I have found it to be very twitchey.
That BIOS you are using is okay but the new BIOS is better.
Also go to OCZ support forums as they post some BIOS setting to use there with VX ram.
at last ...3000 (250 x 12), the board does not like 1.5v, so i used 1.4 v plus he 109% option and everything is okay now,will keep pushing to see how far it will go
my board would not boot with cpu voltage at 1.55 , soon as i changed it to 1.4v with 109% everything ran smoothly.Now to get the water cooling on the graphic cards set up.
Thanks to everyone for the advice...will try benching now ....keep you informed
got fsb to 3120 (12 x 260),voltage at 1.60 and all stable,pcmark 2005 at 14345,graphic cards at 490/1300 will start to overclock these now, whats the best coolbits or riva tuner?
Thanks
Riva is good too as you can (in teh power user settings) disbale the clock test (in Nvidia oiverclocking and global overclocking sections) that throttles your overclocks and find your own overclock limits.
256MB GTX's are good for 500/1400 or higher.
Cheers
Mav
