No LCD on Vapo LS
Aroe
Hi,
I bought a vapo LS from EP about 2 weeks since and finally got round to setting it up last night. Upon testing it everything is fine, still running at standard atm though.
Problem is the first 2 boots the LCD backlight was on (no more than 30 mins run time at this point btw) come the 3rd boot i glanced over and the light is off yet you can still see the text if you look close enough.
I check'd the software and both the backlight and contrast are both at 100% + all cables i can get at are plugged in A'OK.
Has anyone got any solutions to this? or i'm going to have to RMA the thing which i'd rather not do as its not the easiest thing in the world to set up!
Cheers
Andy.
PS. dunno if Asetek would just send me a replacement LCD??
Hi mate is there any chance you could take a pic and post it on this thread? I cant say I've seen this before - it might be a display problem like you say in which case I will have to speak to my supplier and see what we can do.
Fixed it :) ...all that was needed is it turning off at the wall for 10 seconds. Apparently this is a known problem with the LS units and can happen from time to time.
