Nicest looking cooler (with decent temps)?
Dark Rock Pro in my opinion
My Modded Noctua NH D-14
Painted top only to match the side panel paint I did a few weeks back and changed fans to Blue LED Cooler Master Sickle Flows
thanks still deciding if I want to paint those lil nubs on top black break up the green. Was so stupidly simple to paint it lol just masked off the sides with paper and tape made sure the base plate was covered and applied like 4 light coats. Since I'm still waiting on parts figured I'd play a lil.
Yeah painting those black would make it better
The Prolimatech Mega Shadow is also pretty nice imo.
They've stopped making these so you'll be looking for left over stock.
Spire Thermax Eclipse 2 isn't bad as well.
You could always get an NH-D14 toss the nasty coloured Noctua fans and replace then with the Be Quiet silentwing fans. It would drastically improve the NH-D14's appearance
Or just go for the Be Quiet Dark Rock Pro
