Freedom
Hi guys. I'm new to the liquid cooling scene, I've built lots of systems and I'm a freak when it comes to my components looking neat and tighty..
Currently I've got a 3770K running 4.5Ghz on a Asus Maximus V Extreme, I have 16GB of Corsair Dominator Platinum's and all fans in my Switch 810 Matte Black are exchanged with Corsair AF 140's for case fans and the H100i I got is using 2 120mm SP silent series.
Now the questioning comes into play
I want a 360 in the top, approx 50-60mm thick, I have already moved the needed stuff in the top of the case to fit it, I'm only gonna run with push so 3x SP 120 silent series.
Which 360 rad would the majority of you recommend for 120mm which doesnt have a too high SP, quite silent fans, I'm thinking about the fin density and all that.. I see XSPC has one which seems to be good for these kinds of fans but ill leave it to you
And take your advices as Tom kinda has become my Watercooling guru :lol:
In the bottom I want a 240, about the same thickness (50-60mm) and also use the same 120mm SP silent series, so will need the same kind of density in the fins
Pump & Res I can figure out myself, but if you wanna give me any tips or guidance, throw that at me too, it would be great
As for the CPU block.. What to get? I think all the EK blocks looks just, yuck -_- I cant stand the O kind of circles on the block, it looks mega ugly, any other suggestions than EK? And RayStorm is also a no go from XSPC, I have a strict red/black color theme, the block would ruin it with its blue LEDS
Bottom line is; cooling the 3770K and 2x 680s with a 360 rad top/240 rad bottom
When my system is done I will post pictures here^_^ My first time watercooling and I cant wait!
Cheers, looking forward to your suggestions - Kasper/Denmark
