Hi guys, I'm new here and I've recently started ordering parts to replace my old pc. I'd like to go full watercooled this time and I've done a bit of research on it but I'm all ready getting confused.
Anyway here's the parts that I have/have ordered so far:
CPU: i7 2600k
Motherboard: Gigabyte Z68X-UD3-B3
Ram: Crucial Ballistix Elite 1866Mhz 8gb
Gpu: 5770 CF, looking at getting a used 5970
Storage: 3tb various hard drives
Psu: Cm Silent pro 700W (may upgrade this)
Case: NZXT Switch 810
I came up with this list for the watercooling:
Rad 1: XSPC RX360
Rad 2: XSPC RX240
Pump: XSPC Laing D5
Res: ? not really got a clue here
CPU Block: Again not really sure, maybe an XSPC Raystorm?
Gpu block: Going to buy a gpu with one all ready on
As you can see I'm fairly clueless My main questions are:
1. Will this be sufficient to cool my i7 and a 5970 that are both overclocked?
2. Are those rads a good choice?
3. What fans should I use with them? Ideally I'd like to run them both in push/pull but there may not be space to do that with the 360. I'm not bothered about LEDs or anything I'd just like them to be quiet and not too expensive.
3. Should I buy a pump and res combo or buy the res separately? I'd like a 5.25" bay res ideally
4. What coolant should I use? Or should I use distilled water?
5. What would be the easiest way to prevent algae?
6. What diameter tubing should I use?
My budget for the watercooling will be about £400, but lower is better I'd also appreciate it if anyone could have a quick look through my build and see if anything is obviously wrong.
Sorry for all the questions and thanks in advance
Owen
CPU: i7 2600k
Rad 1: XSPC RX360
Rad 2: XSPC RX240
Pump: XSPC Laing D5
  My main questions are:1. Will this be sufficient to cool my i7 and a 5970 that are both overclocked?
 I'd also appreciate it if anyone could have a quick look through my build and see if anything is obviously wrong. Sorry for all the questions and thanks in advance
Owen
