New to water cooling question
Biscuithead
Hi all i have a question about setting up my loop this is my first time setting up a water loop after watching many videos im abit confused on where the tube goes to from the pump should it goto into cpu block first or the rad first, thanks for any help given
Only thing that matters is that your res should be feeding pump directly, order of other loop parts don't really matter.
As Arganos said, Res > Pump .... After that keep the loop clean and as short as possible.
Yup, loop order does not matter at all, as long as your pump comes after the res and is gravity fed (aka in a lower position than your res)
