Hi all,
I've never really needed a graphics card in any of my builds, I don't use them for gaming, just work. However recently started for using on aerial photography with another hobby of mine (RC flying). I have found the graphic intensive tasks when editing and rendering are struggling quite a bit on my current setup so decided to invest in a card.
I've looked around and done some learning but if I'm honest the numbering of the NVIDIA cards still somewhat confuses me however can understand the tech specs. This is where I thought I would use the years of experience here as I've looking but just really not sure on what's a 'good deal'! I understand more Cuda cores is better for rendering/editing so looking for above the 600 mark there at least.
A few key points that would be helpful:
- Mobo: P8Z77-v LX (PCIe 3.0 compatible)
- CPU: i5-3570k (not OC'd)
- Monitors are not 4K but will be editing some 4K footage. running dual 27" matched monitors both have HDMI and DP1.2, however would like to add another 1080 22" monitor possibly at some point
- Would like a card with water blocks available to at some point add into my loop, so guessing reference board preferable?
- 6pin power available from PSU and going in a NZXT phantom case so a fair amount of room available
Can't think of anything else I need to mention other than £100-£150 budget (can stretch a little more if there are significant improvements over the best card within budget)
Thanks in advance for any advice!
