new to folding
zan76
hi guys started folding tonight for here i put my name team number in is that all i need to do .
Yep thats all you need, your name and the team number and your sorted.
If your planning to use your cpu and gpu it would be worth using GPU Tracker V2, super simple and its all in one program.
link http://fahtracker.com/
Welcome
Welcome
If you have any questions just ask away.
Your rig (going by your sig) can put out a nice chunk of points. If you fancy being adventurous you can try out the V7 Beta client.
A few of us here have had some good success with it giving out some work units that have a low base score but with the bonus points added on we are getting some very good PPD (points per day).
You can also fold on your graphics card via the V7 beta client if that's what you're interested in doing.
thank you all. just one thing how long does it take for the point and the ppd to appear.
No worries mate, that is a WU not known by stanford yet,
i have had a few of them now...
You can try "Download Projects list" setup GPU tracker, but didn't work here yet , so waiting for it,
BTW make sure you DON"T click "Check for updates" while the tracker is running (or and if its NOT running) because then you will lose all the work you have done already....
Greetings Ray.......
thought i would leave my other rig folding when i went to bed last night evga gtx 550ti what a bunch of crap folding 13 hours to do what my gtx 570 can do in 2 1/2 hours same points but the ppd was only 2300 ppd ..
thought i would leave my other rig folding when i went to bed last night evga 55ti what a bunch of crap folding 13 hours to do what my gtx 570 can do in 2 1/2 hours same points bu the ppd was only 2300 ppd ..
Do you mean on a GTX550Ti it only gets 2300PPD , because that's not right at all , should be around 8000/9000PPD...
Like SnW said. Those number are not right.
First thing I would check is that the card isn't stuck at 2D clocks. You can do this with MSI Afterburner or GPU-Z.
it's cool got it sorted now just over 9200ppd and 3 hours instead of 13
