OK I am planing my new system, I was going to wait for a 2011 socket PC but I do not think I need such work station performance, So I am planing a gaming 1155 System. It will be used for other tasks such as web editing, photo editing and also Running VM ware (Not constantly only for testing software and also playing
Few new things coming out I am waiting for.
Case - Fractal Design FD-CA-DEF-MINI-B
CPU - Intel i7 2600k
RAM - Corsair Vengeance 1600Mhz 2x4GB or 4x4gb kit (It isn't that much expensive and instead of upgrading latter I can have a complete matching kit up front of use the other RAM in my second PC)
CPU cooler - NH-D14
Motherboard - ASUS Maximus IV Gene-Z Z68
Power Supply - Corsair AX-850
I already Had SSD and other HDD's keyboard, Asus 460 GTX 1gb Direct Cu, screen so on so Only upgrading the parts I need.
OK Few things I am unsure about and also would like people opinions
Well Since the Mobo isn't out yet I don't know how far away the RAM is from the CPU socket.
I am not sure If the RAM will fit under the CPU, I know it wont but I see a lot of people raise the fan so it sits a little higher on the heat spreader fins and make it possible to fit high profile RAM on their motherboard, I cant get mushkin RAM in Australia as it is hard to get hold of in other countrys and even harder here :'(.... Thoughts?
If I can't get the NH-D14 there dosen't seem to be any preformance options besides the Corsair H70, or the H80/H100 that is coming out soon. I am not a huge fan of the cooler as I like the preformance of the NH-D14 as it almost seems it has no limits at the moment alway some one coming out with a even higher OC with it or I just get XMS3 RAM
CPU cooler - NH-D14
