New Sandybridge-E build
TonyTBR
Right im going to uni this year and i want a new beast rig that will get me all the girls, lol jk, but i want it to be beast, im planning on doing very little studying and a lot of gaming, and possibly some video rendering. Here is what ive got so far my budget is around £2000 including peripherals.
Intel Core i7 3930K-£450
ASUS Rampage 4 Extreme BF3-£316
Corsair Vengeance 8Gb DDR3-£40
Corsair H100-£82
Western Digital Caviar Black 1Tb-£85
Corsair Force GT-£95
EVGA GTX 680-£430
Corsair 600T WHITE!!-£135
Corsair AX 850w-£140
ASUS 27in VE278Q-£230
Razer Black Widow Ultimate-£105
Razer Deth Adder-£48
Total-£1746 approx
Please feel free to comment on any improvements or changes as that is why i have done this. Thanks
Get an k90 instead of the razer and get an extra 8 gb of ram may aswell its only 40 more and you could maybe do a small ram drive or ram cache
Yerr i was thinking about going for 16 Gb of RAM don't know why i didn't tbh, i think im goign to go with 16. Ive never looked a corsair peripheralsbut i will have a look now. Thanks
The 670 is a hair slower but a mahoosive amount cheaper. You could even get the 4gb versions when they appear the evga ones are my personal favourite
watercool it properly?
Yeah go for the 670s not 680s. Add an extra 8gb ram. Other things you might want are more monitors. You can pick up some nice 23/24 inch dell ones relatively cheaply.
Another thing you might want to do is add another ssd. If your gaming on it, you can find that the space adds up quickly. BF3 is like 25gb by itself I think, then with all the updates coming up that will get bigger!
I would agree change the EVGA GTX 680 for an EVGA GTX 670, maybe get another 8gb of RAM. If you ever plan on custom WC I would look to buying a reference PCB graphics card.
Change the Razer Black Widow for a Corsair K90 and maybe the Deathadder for Steelseries Sensai or Xai.
I would also advise looking at the Samsung 830 SSD drives instead of the Corsair Force GT drives as they are cheaper and offer similar/better performance at a cheaper price and offer better reliability as the Corsair Force GT drives use the Sandforce controller which isn't known for its reliability.
If you are looking for some speakers look at the Corsair SP2500's or if you have got the room get a pair of the Microlab Solo 7c's and pair them up with an Asus Xonar sound card.
Other than that looks an epic build. Hope the above helps.
this. Good luck with your build mate!
I have decided that i am going to go with 2x670's now and i am adding another 8 gb of RAM, it is still under my budget which is a good thing. i have never loked at water cooling but i will bare that in mind when buying my GPU's.
I have never looked at the corsair stuff but i will give it a look now, the reason i went with the Black widow is that i used it a gadget show live and i really liked it, oh and have looked at the sensai and decided that i am going with that as it a lot better than the dethadder.
SSD wise i haven't really looked at any of the new SSD stuff, i just new that the force GT was good, but im gonna have a better look around for different SSD's.
Speakers wise i thought it may not be a good idea pissing people of with load music in the early hours of the morning so i think im going to go with a headset, can you recommend any good gaming headsets?
Thanks i have decided that im going with two 670's now instead of the 680, im still not really sure on the monitor i just saw that one and it looked good and was HD so i thought i would get it.
Im gonna do some more looking at SSD's i think i might go for a 240gb as well because i am still under my budget
Corsair H100-£82
EVGA GTX 680-£430
Total-£1746 approx
That looks good but I would make some changes also I have some questions.
Firstly how much video rendering will you be doing? If its only going to be the odd video and your pc is mostly for gaming I wouldnt recommend the 3930k. It is a beast of a cpu and I have one myself but I am making one to two videos everyday and thus the extra performance is needed. Plus I will be using my pc for college so I will be using cad, sketchup and photoshop at the same time for presentations. If you are mostly going to be gaming with it then get something like one of the new ivy bridge cpus which I have heard are better for gaming and save some money for other stuff which I will get to later.
As for the motherboard are you planning on doing overclocking or not. If not then the rampage is kind of a waste of money hell I am running an asus sabertooth and my 3930k is running fine at 4.6 ghz at 1.336v in cpuz. The rampage has some nice feature but ask yourself do you really need it other than for bragging rights much like the 3930k.
As for the ram I have 16gb of vengence ram and its really nice. I have no problems with saying to someone to go get 16gb atm as its fairly cheap.
The corsair H100 is a very good cooler and I have one myself.
Now the wd caviar black as I have said to others in the past I wouldnt recommend. I recommend saving your money and get a green then put that money and some extra cash into either a second ssd or a larger one. Your ssd should run your operating system, games and any vital for loading apps. Things like mumble/vent wont really benefit from the ssd so throw them on the hdd with all your media. The reason I said go for the green is its cheaper and since youll be running the main items off the ssd all thats left really is apps that wont benefit really from the extra speed and media. I have a seagate barracuda green and I stream movies off my pc and onto my ps3 and even when fast forwarding or skipping chapters I have no issues with lagging video or anything.
The corsair force gt is good and I have one but I am not too knowledgeable about the reliability so I will leave that to someone else.
The gtx 680 is a good card but I wouldnt recommend it even though I have one myself. Get a 670 instead it is similar in performance and it is cheaper.
Case is subjective so get what you like and get one with enough space for all the components and for the H100 if you go that route.
The powersupply is a great one from what I have read off others on here and I was planning on getting one myself but I just used my old pcs one after realising I wont need that pc anymore.
As for the monitor do you need 27 inches? If your willing to sacrifice a little size then aim for a 120hz monitor. It will make gaming so much smoother and nicer to play on. I have a benq xl2410t myself and would recommend it as its kinda cheap atm.
Peripherals are subjective, a mouse will feel different to different people and so will mousemats. If your planning on buying all this online then try get into a computer shop that sells the mice your looking at and get a feel for them. Hard through the packaging I know but some mice look good in pictures but can turn out to be too small for your hands or uncomfortable. If your gonna be gaming for hours then comfort is key to a good experience. Check out this thread for my opinions on mouse mats.
http://forum.overclock3d.net/index.php?/topic/44682-need-a-mouse-padmouse-mat/
Now if you do go along with the changes I made then with the money saved things that I would add are.
A decent sound card. This will help improve games a lot. It will clean up and make sounds in games better, it will help with pinpointing enemies in fps games.
A decent headset is very helpful for competitive gaming or just online gaming with mates. Something like a sennheiser pc350 or pc360 are good headsets. I have the 350 myself and love them, the 360's are open eared so they will make more noise in your room but your ears will breath easier so you wont get all hot and sweaty. The choice is up to you if you go for one of those, others are available.
Now things you may want to add are a second graphics card or a second monitor.
Maybe if there is enough money left over go down the water cooling route as it can make your pc look very cool and cool it very well.
Now I am no expert on computers but thats what I would recommend from what I have read on here and on the web about the different parts. I recently built my 2nd pc in 5 years about a month ago so I was doing a lot of reading up on parts.
Open to correction on the above if someone feels the need to.
http://www.overclock...rodid=BU-002-SA please consider the RAM I went with, It is cheap and so good for overclocking. I have mine running at 1866 9,9,9,24 @1.35v and I am going to push for 2133 soon.
I would 100% agree with this, after looking over the specs again I would advise changing out the Vengeance RAM for the Samsung green memory. The Vengance memory is good memory however for the little bit extra I would get the Samsung Green RAM, its great RAM and overclocks like a beast. I have seen people get this RAM running at 2133MHz, its amazing stuff, I am looking to use this in my next build.
Good choice the 2 x 670's will give awesome performance, I would definitely stick with EVGA though as they offer great warranty and should you wish to WC the cards later down the line you can do so without voiding your warranty. The 8GB will help when your rendering your videos etc and for the little extra it will make a noticeable difference.
As for mechanical keyboards, you should always go with what feels best to you, the main reason I suggested the Corsair K90 was due to hearing bad things about the Razer Black Widow, I must say I have seen the Black Widow and the gloss finish makes it a complete finger print magnet, so I would bear that in mind. If you like the Cherry MX Blue switches there are other keyboards on the market such as the Qpad MK-80 which use the switches which may be worth looking at. Good choice on the Sensai I am going to be getting one myself shortly. It would be worth investing in a mouse mat to use with the mouse something like the Steelseries Qck series mousemats, just pick the one you like.
As for SSD's, I am a big fan of Corsair products however personally I would chose another SSD, something like the Crucial M4 or the Samsung 830 series SSD's, these are well know to be some of the most reliable on the market and some of the fastest in real world tests. Out of the Samsung and the Crucial I would go for the Samsung personally as its faster and looks aesthetically better for me personally.
Fair enough with the speakers, however you may annoy some people with the click from the Cherry MX Blues.
Headset wise I would look at the Corsair Vengeance 1300's, Steelseries Siberia V2's or the Sennheiser P360s if you want to spend that much. But make sure you pair them with a good sound card, something like the Asus Xonar series cards, maybe the D2X, very good sound quality.
I must agree with the above, didn't notice it before but I would agree with changing the WD Black drive to a WD Green drive for the extra money, its not worth the little performance gain, considering your SSD will be your primary drive and the WD drive will probably be the storage drive. I would get a green drive and spend the money on a bigger SSD or something. I have got a WD green drive and it has been excellent. I would advise looking around as there are some great deals that come about on 2TB drives if you look.
I would definitely stick with the 600T great case for the money and plenty of room for upgrades. Tom build a rig for Hayleywow in one with similar specs, take a look here: http://forum.overclo...-the-wow-e-rig/
If you want to get a really nice looking rig, I would look at getting some sleeved extensions, something like the Bitfenix Alchemy cables, or the Corsair cables for the AX850.
If you have some money over it may be worth looking at investing in some Noctua NF-F12's for the H100, you can possibly get push pull on the rad if you wish in the 600t. Take a look at this:
[media]http://youtu.be/3qAvH3yJ_A8[/media]
