Animal said:Nice dude,
Got any pics of inside and with the side off.?
Gray Mole said:you just can't beat the look of a well made watercooled PC![]()
name='justin' said:looks great, but i would put some little plastic ties on the loop out of the rad to avoid kinking.
Gray Mole said:Wow, I love how you've done the side window too. Looks really classy.
I have to say, that while phase is always gonna be my first love, you just can't beat the look of a well made watercooled PC
Cheers
Gray
name='phil123' said:did you cut holes in the bottom of the case for the fans? or do you just let the air come through the standard drilled hole surface?
stocky said:Woah - not much bottom left there!
Does bolting the rad help give additional stability, or do you notice much flex?
What kind of results are you getting from the system?
