New Rig Specs, what do u think?
GODuk
Hi all, im doing a build for my supervisor in work.
He has given me a budget of £1200 but i can get it all for £1099.17
Here is my list and please tell me what you think:
CoolerMaster HAF X case for £130.76
ASUS P67 Sabertooth B3v £139.99
Corsair CMPSU-850AXUK AX 850W £142.62
i5-2500k 3.3Ghz £159.78
MSi GTX560Ti FozR2 £178.99
Corsair Memory XMS3 8GB DDR3 2000Mhz £86.16
Noctua NH-D14 £69.98
WD 1Tb 6Gb/s SATA3 £62.41
OCZ Vertex 2E 60Gb £80.99
BluRay Combo SH-B123L/RSBP £47.49
*Updated PSU & RAM*
Looks good - think that I would go for a Vertex 3 or new Corsair Force series. If he got the money I'd get the fully modular AX psu as well, it'll make the build much neater, and cable management will be a breeze.
I assume you're going for a 2500K at that price?
do not forget to charge him for putting it all together too
(plus installing the software and tweaking it for him/her)
EDIT: i charge anywhere between £120 and £150 for doing it, as sometimes it is straight forward and other times it is a PITA, and could take longer than a days' work
Yeah he's your supervisor not your mate make sure you charge him for your time.
@ S_I_N. My mistake, im using my mobile, should proof read
lol
@Tom. Noted mate, did notice not long after posting but forgot to amend, will amend tonight at home.
@BoS. Cheers, will check for some low profile sticks.
My supervisor is giving me £50 yo build it for him
Which RAM to get, the Corsair XMS3 8GB or 8GB Mushkin Radioactive?
Both are low profile.
I like the idea of the radioactive which will match the army style sabertooth mobo.
Well I'd go with the Mushkin Radioactive tbh.
You looking at the 1600Mhz? On Aria, for 10p more, you get RAM with better clocks, lower voltage.
