New Rig Corsair 600T, 2600K, Noctua NH-D14 etc
billeman
crossfire.jpgCorsair 600T
Asus P8P67 Deluxe
Intel Core i7 2600K
8 GIG 1333 Mhz DRAM
Noctua NH-D14
Sapphire AMD HD6950
Corsair HX850
OCZ Vertex 2 SSD 120 Gig
Plextor PX-B320SA
Cheers
[EDIT] Added Backside Messy Cabling :> In the lower right corner you can see the dismounted USB 3.0 3,5" Adapter without the case, just the cable. I plugged in the USB 3.0 front panel from the case into that one.
[EDIT 2] Added new photo with second HD6950 card, both shader unlocked but no overclocking. Added Noctua fan to better cool the upper card.
MOAR pics
Thanks for the comments guys
Have to find another way to attach pictures since I'm hitting my quota already.....
I'm not really into http crosslinks etc, my work concerns mainly routing and firewalling the lower layers of the OSI stack :>>>
That's actually quite smart.
Nice rig, looks good, nice and tidy, while sporting some pretty beastly specs.
Any chance of a shot at what the rig looks like in the dark?
I like the 600t. I think an all black corsair build would be sweet. Nothing white but the corsair sails
thumbs up!!
If only Corsair had made a larger version of the 600T. The obsidian is SO BAD its almost as if its not made by the same company.
yer cos airflow isent the most important thing in a case
I have the impression this is a somewhat synical reply, isn't it ? :>
With regard to airflow in the 600T, I don't think it's the best to be found, above average I would say.
At least with the standard fans, that is. I have the impression that the 200mm fans don't really move a lot of air, they are only 20mm thick. And there's really no room for 30mm's it seems.
Maybe putting 2 x 120mm's in the top would improve things, for me it's not an issue really since I probably won't be running crossfireX etc, and the temps stay reasonable when stressing the computer.
Exactly!! What point is there to making a good looking case when the air flow is pure shite. I honestly don't understand why its been selling so well. Probably bought by the same people that buy the dumb H70 kits. IDIOTS!
