PHILIP1193
this is the mother of all test programs better than prime!!!
If you wanna know how hot your proccessor will really get, then get this im worried as mine hit 56 degrees where as i never seen it go above 48
basically down load the program go to teh settings bit change the load slider to 100 and watch as teh 4th test runs watch your cpu temps soar, the go about 5 degreees higher than prime after a certain amount of time!!!
i am so supprised and believe me it test stability i can priem for ages but this fails pretty much instantly
back to teh drawing board!!!
Outta interest people who decide to use this post back weather yr stable and the top temp uhit using this and then the normal load temp u get!!
d/l program here http://testmem.tz.ru/snm.zip
phil
phil
