Commander_Z
Not sure where i should post this
So i built my new PC, and today i planned to reinstall windows, but it wont boot
My system spec
Case: Air 540
mobo: Asus Z97-A
CPU: 4690K
Ram: 2x4GB Adata XPG 2400MHz
CPU cooler: Corsair H100
PSU: Antec HCP 1000w platinum PSU
HDD: reusing a WD 1TB Black
2nd HDD(to install later) WD 2TB Green
Thermaltake Commandar F5 fan controller
TP-Link WN751ND PCI wifi card
GPU: Asus GTX 970 Strix 4GB
2x Samsung 24 inch monitors, one connected via HDMI, the other via a DVI-VGA connector.
Bios version: no idea
I have reseated the 24 pin, the 8 pin CPU power, and the 8 pin GPU cables before posting here.
The ram has been reseated in the reccommended slots according to the manual
All 5 fans (3x 140mm case fans, and two 120mm fans on the H100) are attached to the Thermaltake fan controller.
The H100 pump is connected to a molex PSU connector and the 3 pin pump connector is plugged into the CPU fan header.
A white led is light up on the GPU, the yellow led below turns on when the switch is moved to the up position, otherwise off when in the down position. There is a yellow led illuminated above the pwr led/pwr sw button.
The switch on the back of the PSU is set to I
When i pressed the power button on the front of the case, the two fans on the GPU briefly spin up and the mobo makes a short beeping sound.
Additionally the blue leds for each fan control switch briefly light up as well as the red power led just above it.
The 1TB WD Black has an existing install of windows 7 home premium that was attached to a system running a FX-6300 and a Gigabyte 78LMT-S2P, and so I am trying to reinstall windows on the drive from a bootable windows 7 usb.
Is this the problem due to the old installation on the drive?? do i have to format it before hand??
I think this is all the information i can think of
Thanks in advance
My system spec
Case: Air 540
mobo: Asus Z97-A
CPU: 4690K
Thanks in advance
