Hi Guys,
Hello,
I have just sold my previous gaming pc and need to get a new system. In two words, this will be purely made for gaming.
I enjoy putting them together, over-clocking and gaming from time to time.
Heres what I had in mind:
Cosmos 2
ASUS Maximus Formula V
i7 3770k
EVGA GTX 690
Samsung 840 Pro SSD
G Skill Trident X 2400
Now, for this system I wanted to create a proper water cooling loop. I've had the Corsair H series in the past which is OK, but I wanted to go for something more special.
At first i'll be just water cooling the GPU and motherboard (which has integrated cooling) but eventually will add a block for my 690. I wanted to know if it was worth getting a proper loop rather than a H100i or the new Eisberg 240.
I was thinking of getting:
RayStorm 750 RS360 WaterCooling Kit
or
RayStorm D5 EX360 WaterCooling Kit
I've heard that the 750 pump is not very reliable, however the RS system is relatively cheap and only £50 more than the H100i. This will also be my first water cooled build and the pump/reservoir combo seems practical.
I've also heard mixed opinions about dye's. For me it will be very important, as a big factor of the water cooling is that its aesthetically pleasing.
Additionally, will an AX860i be enough? What would be your recommendations about the water cooling and about any other parts of the build? Should I change anything else?
Thanks a lot!
Hello,
Cosmos 2
i7 3770k
EVGA GTX 690
Samsung 840 Pro SSD
or
Thanks a lot!
