According to the folks at HKEPC ( does who also cracked crossfire ) Nvidia will be releasing a low end version of the 6600LE which will be based on the NV43-V GPU ( the same GPU of the 6200 )
Some Specs:
Core Clock: 425MHz
Memory Clock: 500MHz
GPU Core: NV43-V
Price: US$60-70
So whats the good part?? The good part is that it's SLI-Capable and because it is based on on the same gpu of the 6200 you can unlock the other 4 pipelines which could make this VGA a wanted one.
This is something interesting which you may like
I wonder if you get the Galaxy one with memory @ 1ghz and unlock the pipelines 4 pipelines and i think this low end vga will be better than a vanilla 6800 and remember you can SLI these aswell.
Source: Bit-Tech
Some Specs:
Core Clock: 425MHz
GPU Core: NV43-V
Price: US$60-70
name='"Bit-Tech"' said:While we understand that Galaxy are likely to launch a GDDR3 version with the memory clock speeds increased from the believed reference clock of 500MHz up to a mighty 1GHz.
Source: Bit-Tech
