new NB cooler
deepfried
right im currently borrowing, and soon to purchase ionicles old socket a board, but due to the small rather inadequate HS on the nb, im scared to overclock, as it gets damn hot on normal operation
i need a 40 mil hs with fan...but it cant have the power connecter for a gfx card
do any of you know anywhere to get a nb hs with fan that goes into 3 pin fan slots/ molex? if so, any finds would be v.helpful
if not, im goign to have to convert a gfx card hs at this rate:(
Actually a small GFX heatsink wld work well..
& Why cant you use a Molex connector? You can daisy chain them. I have my 2x 120MM fan's, and CCFL's all daisy chained.
well ive had alook and i may as well get a 40 mil gfx hs/fan
its somthign ive nevere doen before, so how do you convert it from the tiny power conncter to a chassis fan connector or molex? sorry if theres some obvious answer ive missed :o
so many choices.... i think im going to get the Akasa AK-210, and simple, besides, ive got a 3 pin connector right next to the NB going spare:D
