SmoulderingCircuits
Gigabyte GA-E350N-USB3 (1.6Ghz dual core 40nm, 40nm 500Mhz 80 Radeon cores on die) http://www.ebuyer.com/259099-gigaby...cessor-onboard-vga-dvi-hdmi-7-1-ga-e350n-usb3
Extra Value black ITX chassis + 250w PSU bundle (system will use around 45w http://www.ebuyer.com/205560-black-mini-itx-case-with-250w-psu-20-4pin-with-sata-pix1001
4GB GSkill Ripjaws DDR3 1600Mhz 1.5v 9-9-9-24, the reason for the high frequency is frankly it will make a significant difference to the 6310 and although technically only 1066Mhz is supported I have seen up to around 1500Mhz work in reviews on that board, so am happy just to get an overpowered module and downclock it http://www.ebuyer.com/264749-g-skil...y-module-cl9-9-9-9-24-1-5v-f3-12800cl9s-4gbrl
450GB Samsung HDD 7200rpm (already have this from previous build)
Cheap skate keyboard http://www.ebuyer.com/202780-xenta-black-full-size-keyboard-usb-uk-layout-hk-6106
I plan to take this to school (bit of an excuse really) for my I *ahem, english with a computer, ahem* T course and for when I stay around my brothers house so I don't have to bring the main rig out and have it clunk around in the car.
Hence, I don't see need for a display as there are plenty at the places mentioned and around the house I can connect up to. I might order another cheap slimline keyboard for it too (already have a spare mouse).
All in all, (£17.14 + £131.02 + £26.11 + £2.99) £177.26 (last time I calculated) is not half bad for another system (was going to get an Xperia Play origionally, but Windows is more productive than Android).
