Mr. Smith
"We call this processor Core 2 Duo but really it's Core 2 Duo on steroids. This microprocessor is going to be more powerful than the previous generation," said Intel's mobility chief, Mooly Eden.
The new chips will be able to overclock one of the cores if the other core is not being used.
"The idea is the following," explained Eden. "If you are running a single threaded application, one of the cores can go to sleep, and the left over power can be used by the other core - we give it a turbo boost; the ability to run faster than it used to.
"This is not overclocking. Overclocking is when you take a chip and increase its clock speed and run it out of spec. This is not out of spec. Here, it is within the spec of the dual-cores, we just identify when one core is not using the headroom and we give it to the other core.
"This is called Enhanced Dynamic Acceleration Technology. We've had problems implementing it, but we've been able to do it in Santa Rosa," Eden said.
Get the full story here
