New CPU
Dave8
Hi i have been with AMD for as long as i can remember and have now decided its time to try out Intel
I have been given a choice of cpu, They are
Intel Core i7 2600k 3.4GHz Socket 1155 8MB Cache £249.52
Intel Core i7 2700K 3.50GHz Socket 1155 8MB L3 Cache £269.24
What would you recommend for gaming
£270 is my max budget and cant go one penny more due to the other stuff i am buying
And cant afford the stupid high price of socket 2011 boards
I'd get the 2600k and put the £20 you save towards something else.
The only difference is an extra 100mhz on the 2700k, not even noticeable. They are also meant to overclock slightly better than 2600ks but thats not guaranteed and you could end up with a 2700k that is worse than a good 2600k.
It might be worth waiting to see what ivy bridge gives next month if you arent in too much of a rush.
Otherwise a 2600 and 2700k is the same if you are OCing as sieb says.
Needs to be asap as av already sold the rubbish that's in this just now
So its the 2600 then
Have also bought the h80 cooler, will that be ok for overclocking this cpu
Have decided to go for the H100 as it seems that it will fit in my Corsair HAF.
What would be the best fans for that as i hate noise but still want to push this CPU
Tom gives the Noctua Focused Flow fans a nice review here
I know those fans are expensive, if you don't want to spend that much I would look at Bitfenix Spectre Pros, which are also great fans for the money and quiet aswell.
Review of the Bitfenix Spectre Pro review here - http://www.overclock3d.net/reviews/cases_cooling/bitfenix_spectre_pro_range_review/1
Hope this helps
For gaming? i5 2500K for sure, i7 won't make the difference. Invest the rest in something else ;-)
2500k, my i5 can kick the crap out of most people 2600/2700k. 5ghz FTW! also a 2600k/2700 for gaming is pointless and wont perform any better than a 2500k.
True but a 2600k is a little more future proofed because you can use HT to free up your 4 cores should the cpu start bottlenecking. You can always OC it with HT off in the meantime. Depends on how long you want to keep the cpu for I think...
I think 5ghz is is pretty future proof.
I noticed that my fps dropped between 1-5fps, when I switched from a 2500K to a 2700K.
If you have the money and want it to last a few years then either the 2600K or 2700K will be fine, and with a decent cooler you can overclock the nut's of it.
There's quite a lot to say here but it basically depends on your upgrade cycle - there is no right or wrong.
An i7 with ht off is an i5. They will clock the same and perform the same.
With ht on the i7 will oc slightly lower for the same volts because the ht increases the power demand. This decreases performance per core but increases overall performance across the 8 threads.
This doesn't mean that an i5 is going to bottleneck in the near future but a 2600k is still more future proofed. This is because the point at which an i5 would bottleneck would be the same time that you could turn on ht on the 2600k and keep using the chip because games are increasingly making use of more threads.
Technically this could be taken to the next level with a 2011 - cherry pick the best 4 cores to OC on in the meantime and switch back on the others and then ht when you need to in.the future. However the cost of getting this setup is £800 which is 1.5 times that of an i7 build and twice that of an i5 build so to get the value out of it you need need the chips to last proportionally longer since we aren't making use if the extra threads any other way. Currently the 2011 socket also has the advantage of not being end of the line which IB is to 1155. The intel socket plan i saw recently had x-e continuing past IB-e so you would have the option of only needing to upgrade the mobo or cpu rather than both.
So back to the upgrade cycle for gaming:
If you are the kind of person who will get around to upgrading the cpu every year then the i5 is for you since you'll never use the spare capacity of the other chips.
If you plan on keeping the cpu for a couple of years then the i7 quad core could come in useful, especially if you run cf/sli since you have to feed more gpus. Aria currently have a great deal on a 2600k for just £210 which admittedly I'm very tempted by!
There are several people on this forum who also swear by the x-e range and have bought them for gaming. They keep their mobo/cpus for 3+ years and get their monies worth that way plus have the versertility and power in the short/medium term. You have to keep the hardware alive for a longer time this way too though...
@ NotSoBright,
All are good options, none of them are bad chips. Just pick the one which suits your needs.
I got the i7 2600k and the H100
also got an asus board and the mouse click bios has confused the hell out of me.
Also never had intel in my life before i have no idea what any of the bios settings do.
Any help or links to what it all means would be great so i can start overclocking this cpu safely
