Arabicuser
I started to build my computers about 2 months ago, i was planning for 1 build but by mistakes and wrong decisions i ended up with 2 or 3 builds, one build will be for kids but i can use it if i want, so i will be more focusing on another 2 builds i did, and i hope i can have help for next steps, what i bought is done, no need to tell me go and replace or buy something else unless it is not about the CPU/PSU/Mobo, GPU and SSD and even case i can change, but just let's see what i can get here as advises and discussions.
Let me just give you the list of my 2 rigs components so we can go from there:
1st rig build:
CPU: Intel i7-3930K
Mobo: Asus Rampage IV Extreme
RAM: Patriot Viper 32GB 2133MHz
GPU: Gigabyte GTX Titan Windforce OC version
Cooling: Corsair H100i
SSD: Not sure yet, but my Samsung 840 Pro 256GB is inside waiting, i may change and buy 512Gb or buy another 256GB
HDD: WD Black Caviar 2TB 7200rpm
PSU: Seasonic X-1250W
Case: Cooler Master HAF X
_____________________________
2nd build:
CPU: Intel i7-3820
Mobo: Gigabyte GA-X79-UD5
RAM: Corsair Dominator Platinum 16GB 1600MHz
GPU: Gigabyte GTX 660Ti Windforce OC version
Cooling: Corsair H60
SSD: Corsair Force GS 128GB [i have problem in this system for booting and speed for SSD under first fresh Windows 7 installation]
PSU: Corsair AX1200
Case: Thermaltake Overseer RX-I
_______________________________
My second rig is finished, but i still not so happy with it before i go and install any drivers or whatever needed, my 3rd rig with simple cheaper components is much much faster and i never installed anything yet for BIOS/drivers/firmware, so i don't know what issues i have with that 2nd rig yet.
I didn't finish my 1st build yet, i stopped now with PSU installation, i just plugged few cables but not all yet and not sure which cables/wires more to connect and to what parts, and most important how can i manage to keep my wires/cables clean management?
1st rig build:
CPU: Intel i7-3930K
2nd build:
CPU: Intel i7-3820
PSU: Corsair AX1200
