New Build
Rigi
Budget: $1600 USD
CPU: i5 2500k................................................................................................................$219.99
CPU Cooler: Corsair H70............................................................................................ ...$104.99
Mobo: Asrock Fatal1ty Pro P67 (Only Red Mobo that Supports my GFX in SLI)........... ..$249.99 (MSRP)
GFX: Asus Gtx 570 Direct CU II (SLI in about 2-3 months) 3 Slot Video card.................$349.99
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR31600 9-9-9-24............................ ..$99.99
PSU: Corsair AX850 or NZXT 850W Hale90............................................................... ...$179.99
HDD: Samsung F3 1TB x2 Raid0............................................................................... ..$129.98 (64.99$ ea.)
Case: Bitfenix Colossus (white).............................................................................. ....$169.95
DvD Drive: LG Black........................................................................................................ ..$17.99
Win 7 Home.................................................................................................................$99.99
Total..........................................................................................................................$1,617.00
for Gaming, will be OC
I know that the D14>H70, but the color on it just kills it for me -.- And i like how the H70 looks
No Retailer has the asrock fatal1ty P67 B3 in Stock yet (one has extreme6)
This will be a Red White and Black Themed Build
Extreme6 and Fatal1ty are very Similar in Specs, fatality is just $30 USD more but its better looking (other than the Bios background -.-)
Retailer Combos basecally Counter Shipping Expenses
Any Suggestions, or incompatibility
also what psu out of those two should i get? nzxt has shorter eps 8pin and 24pin connectors
sorry for the mess
cooler shouldnt really matter about what it looks like surely you want performance and the nh-d14 would outperform that.
mobo wise never used asrock before but i would rather go for asus/gigabyte/msi board
ram have you looked at mushkin?
psu they are both good wont be dissapointed either way
Are you planning to overclock your CPU? Because from their past motherboards I wouldn't recommend getting an Asrock motherbaord. I would rather go with something from Gigabyte/Asus/MSI. For the cooler, if you are set on the H70, there is no need to try to convince you not to get it. But the H70 doesn't perform well in many situations.
For memory, I would advice you to look at the Kingston memory OC3D reviewed today. It's the Genesis at 2133 Mhz speed. I don't think you will need 8GB of ram unless you are doing some heavy video editing. Everything else looks good
Theres a Review Here on the Asrock fatal1ty, looks good, and on par With the others , in the Conclusion they also put in that They have been working Really hard to Get their Reputation up and no Longer Want to be Known as Just a OEM/Budget Board manufacturer, they want to compete with Asus ROG and Gigabyte UD7
Their Overclocking looks Good aswell plus We get 1 year extra warranty if anything Goes wrong
so 4 year warranty
As for Ram i think i might go with The Mushkin Ridgeback
to Save an extra 10$ im going to go with the NZXT Hale 90, since i Will just buy NZXT Extensions
Will be ordering my Stuff 1 week after Gtx 590 is released (hoping for Price drops) If im able to get my hands on a Board by that time (super low stock)
*Question for Tom (if you read this)* Will you be Doing a Review on the New Asus gtx 570/580 Direct CuII Cooler?
I saw an unboxing of that asrock fatal1ty, and man does it look sweet. As they have been saying, yah asrock is trying to get into the mainstream performance game. Its too bad that wendell guy is such a dork.
Lol I hate the bios picture on it, Hope Asrock implements a way to Change it, like the Fatal1ty logo ("F") but might not happen.
