Hi, I have been saving up for a while now and I have a few parts sorted, they are as follows:
CPU: I5 3570k
Cooling: h100 or h100i (depends on whether I decide to get more fans that I can chuck on the h100 anyway
SSD: either corsair force gs 180 gb or Samsung 840 pro 120 or 240
HDD: seagate 2tb st2000dm001
PSU: corsair AX860 or 860i (is there much difference?)
RAM: corsair vengance 16gb 1866mhz cl10
Graphics card: 2xmsi gtx 670 power edition (will take advice on this as well if you think I should change, I wud like to get a red one as I like the colour scheme but I might have to give that up because of the prices of any dc2 g card atm)
Case: CM Storm Stryker (would have chosen trooper + window bu the don't make it any more) or nzxt phantom enthusiast with a window
Case cooling: probably a couple red led fans and the rest maybe corsair 120mm case fans
And this is where I'm really stuck.
Mobo: either asus Maximus v formula with thunder fx or asus sabertooth z77
Sound card: if I go with the sabertooth I will probably get the asus xonar Phoebus as apparently the drivers have been updated and are now working the way they should so the Phoebus is now much better
Any advice on any part is appreciated. I can't really spend any more than what is specified above. I live in New Zealand and parts here are beyond overpriced so I will be ordering from the USA.
I will order In different packages because as long as I don't go over $400nz then I don't need to pay any import tax. So that means that if I get the sabertooth and the Phoebus I will not have to pay extra 15% gst but but if I get the Maximus v formla with thunder fx I will need to pay gst so they work out to be close to the same price.
Thanks for taking your timeto read this, it's greatly appreciated XD
Oh, and I would like to go down the nvidia surround road at some point or at least get a good 27" monitor, like a vg278h or maybe a 1440p monitor if I can find the funds
CPU: I5 3570k
