V vexb New member Sep 23, 2014 #1 Hi there I recently put together this new build list but I'm unsure if the cpu is compatible with the ram. Here it is -> I'd really appreciate some insight if there's any compatibility issues. Thanks a million Last edited by a moderator: Sep 23, 2014
Wraith Bettyswollocks Sep 23, 2014 #3 Why have you decided on EEC Registered server RAM? ASRock support says that the X99 Extreme4 won't support it.. http://www.asrock.com/mb/Intel/X99 Extreme4/index.us.asp?cat=Memory
V vexb New member Sep 24, 2014 #4 Thanks guys for pointing that out. Would you recommend a kit to replace it? Because I'm having trouble finding 64 gb dimms on amazon.com
